ssriram1978's avatar
ssriram1978
AC3200, R8000 does not support "dev tun"
I am trying to use openVPN client in my iOS device to connect to my AC3200 router.
AC3200 does not support "dev tun" option in the ovpn setting.
I am unable to login to my VPN from iOS device.
However, I had AC1900 (R7000) which supported "dev tun" option in the ovpn setting.
I sold off my AC1900 and upgraded to AC3200 but it looks like I need to fall back to AC1900 because AC3200 does not "dev tun" option.
When are you planning to support "dev tun" option in AC3200?
Thanks,
Sriram
  • FURRYe38's avatar
    I'd contact either phone support about this or send a message to Elaine, one of the forum moderators about this. Good Luck.
      • ssriram1978's avatar
        ssriram1978
        Thank You.
        Here is the client debug log and it clearly points out the failure reason.
        2017-04-26 10:52:46 SSL Handshake: TLSv1.0/TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA
        2017-04-26 10:52:46 Session is ACTIVE
        2017-04-26 10:52:46 EVENT: GET_CONFIG
        2017-04-26 10:52:46 Sending PUSH_REQUEST to server...
        2017-04-26 10:52:46 NET Internet:ReachableViaWWAN/WR t------
        2017-04-26 10:52:46 OPTIONS:
        0 [route] [192.168.0.1] [255.255.255.0]
        1 [route-delay] [5]
        2 [redirect-gateway] [def1]
        3 [route-gateway] [dhcp]
        4 [ping] [10]
        5 [ping-restart] [120]
        2017-04-26 10:52:46 PROTOCOL OPTIONS:
          cipher: AES-128-CBC
          digest: SHA1
          compress: LZO
          peer ID: -1
        2017-04-26 10:52:46 EVENT: ASSIGN_IP
        2017-04-26 10:52:46 TUN Error: tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified
        2017-04-26 10:52:46 EVENT: TUN_SETUP_FAILED tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified [ERR]
        2017-04-26 10:52:46 EVENT: DISCONNECTED
        2017-04-26 10:52:46 Client exception in transport_recv: tun_exception: not connected
        2017-04-26 10:52:46 Raw stats on disconnect:
          BYTES_IN : 3498
          BYTES_OUT : 2619
          PACKETS_IN : 35
          PACKETS_OUT : 35
          TUN_SETUP_FAILED : 1
        2017-04-26 10:52:46 Performance stats on disconnect:
          CPU usage (microseconds): 79480
          Network bytes per CPU second: 76962
          Tunnel bytes per CPU second: 0
        2017-04-26 10:52:46 EVENT: DISCONNECT_PENDING
        2017-04-26 10:52:46 ----- OpenVPN Stop -----
