Axeldook's avatar
Axeldook
AC5300 Nighthawk X8 Smart WiFi Router R8500 uk release date
Hi,
Does anyone know when this router will be released in the UK please.
thanks
  • Possible release will be mid-December of this year.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    Someone may come up with a quicker answer, but otherwise I will enquire later today when I get home from work, about 7 hours from now.
    I was on the beta test for that router and have it set up as an AP right now (works perfectly well as a router also). My ISP is Virgin Media so the very impressive wireless throughput that the R8500 provides is very welcome.
    Use with a compatible Link Aggregation NAS is also very impressive with transfer rates at the full gigabit rate over my very busy LAN, easily hitting a sustained 100Mbytes / second.
    • Axeldook's avatar
      Axeldook
      thanks Andy,
      I look forward to hearing from you.
      The R8500 router has some impressive specs. Keen to upgrade from my R7000...
      • Babylon5's avatar
        Babylon5
        I do have quite a few routers, currently I’m running six concurrently (that’s about 15 different SSIDs), and that includes the R7000 which is one of my favourites.
        I have found that the throughput and performance of the R8500 is noticeably higher than the R7000, and as I mentioned above the Link Aggregation feature is a must-have with a compatible NAS.
