ThornlessMule
Aug 24, 2021Follower
AC750 model R6020. Can’t connect router to Apartment WiFi.
I live in an apartment that provides WiFi as a part of the rent. It’s a public network and you have to log in to a portal and add the MAC addresses of the devices you want to use. So I’m trying to add the router but running into an issue when I try to connect it. I have it connect to the Ethernet port in my room and I added the MAC address but it still refuses to connect. Any ideas?
Edit: I should also add that I know it’s possible to set up a router here because when I look at the WiFi networks there’s tons of them around me
1 Reply
If the wifi and the ethernet are provided, its already got a router running. its called a double nat.
What is Double NAT? | Answer | NETGEAR Support
How to fix issues with Double NAT | Answer | NETGEAR Support
