vt460
Mar 22, 2018Aspirant
Acceptable distance from Nighthawk X4S to unmanaged switch?
hi, Anyone know what is a comfortable cable length that should work from an X4S LAN port to a Netgear FS108 uplink port? My setup is cable modem -> X4S on the second floor of a home. I cannot move th...
- Mar 22, 2018
> [...] Anyone know what is a comfortable cable length that should work
100m is the usual limit.
https://en.wikipedia.org/wiki/Ethernet_over_twisted_pair
As you've observed, an FS108 is not a gigabit switch, so using it
with an R7800 could add a new bottleneck.
> [...] When I put everything in the same room [...]
If "everything" really means "everything", including all the gizmos,
all connected the same, then I wouldn't expect any less-than-house-size
cables to matter much, unless there's something wrong with the cables or
one of the switches.
> [...] I am able to use a pass through cat5E connector in the basement
> and that works for a single connection to the IP phone, but I can't put
> the FS108 in that same location.
You might try a (cheap) gigabit Ethernet switch instead of the FS108,
if the cables are good.
Mar 22, 2018Guru - Experienced User
I presume there are two issues,
This coupler which I would not use.
Your switch is a 10/100 max speed switch.
https://www.netgear.com/support/product/FS108
While the R7800 is a up to 1000mb speeds on it's LAN ports. So your having a bottle neck of some sorts. You can use a 100Mb switch however its always best to keep same max speeds as your router supports throughout the LAN network if possible. I would only use 100mb switches for printers and older legacy devices.
Gb switch:
antinode
Mar 22, 2018Guru
- vt460Apr 06, 2018Aspirant
I've installed a GS308 and it's working. I wish I knew why the FS108 didn't work but I have no idea. Thanks for the advice.
