Thomas_FR
Oct 28, 2021Follower
add RBR50 a backup dongle 4G
hy, (i'm french). i would like to know how it's possible to add to my RBR50 a 4G cellular backup? the objectif is to switch to the 4G cellular connection when the main internet connection ADSL doe...
Oct 28, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Thomas_FR wrote:
hy,
(i'm french).
the objectif is to switch to the 4G cellular connection when the main internet connection ADSL doesn't work.
thanks for your helps
