viall26
Jan 18, 2019Aspirant
Adding a GS108 switch to Nighthawk R7800
I have a new home with a smart panel that has all rooms wired for cat6. I have tried adding the GS108 to my router and lose my wireless network. When I unplug the switch and restart the modem and rout...
- Jan 19, 2019
Does this problem happen when you plug in the Ethernet switch with nothing connected to the switch? If just plugging in the switch causes the problem, I would replace the switch. If things are normal with nothing connected to the switch, try adding one Ethernet device at a time. Power each device off/on before adding it.
antinode
Jan 18, 2019Guru
> cat6. [...]
Define "smart panel". Is it any more than a patch panel? Are
devices already connected to the room ends of these cables?
> [...] I have tried adding the GS108 to my router [...]
"adding" how, exactly? What, exactly, are you connecting to what,
exactly? Hint: If a device has multiple Ethernet ports, then "connected
to device" is not enough detail.
> [...] and lose my wireless network.
What do the LED indicators on these devices indicate?
Visit http://netgear.com/support , put in your model number(s), and
look for Documentation. Get the User Manual(s). Read. Look for the
LED indicator descriptions.
> [...] What am I doing wrong?
Need to know what you're doing, first.
You should be able to connect any one Ethernet port on the switch to
any one LAN Ethernet port on the router. Other devices should be
connected to open Ethernet ports on the switch or open LAN Ethernet
ports on the router.
A plain GS108 is an unmanaged switch, and should be too stupid to
cause any serious trouble all by itself.
viall26
Jan 19, 2019Aspirant
Each room is wired for cable and two cat6 ports. All that wiring feeds into the panel. I also have my direct tv and Clare home solutions coming into the panel. Inside the panel I have my Arris modem and nighthawk router. I have my wireless network working correctly. I purchased 1ft cat6 lines To hardwire a couple devices into the router. My kids computer is plugged into the port in his room and a 1 ft cat6 from its designated spot in the panel to the router. Same with the living room TV. My goal is to add all the rooms to the available ports in the gs108. I plugged the switch into port one of the router and port one of the switch and proceeded to add the remaining cat6 lines from the ports in the panel to the switch. The lights on the switch that are active are green. The lights on the router corresponding to the ports are white. The light corresponding to the wireless signal is Amber. I have also tried plugging the switch into port one of the router and port 8 of the switch. Ports in rooms not receiving signal and no wireless signal. Unplug switch and put all connections back the way they were originally and restart modem and router and all signals return to room ports and wireless.
- myerswJan 19, 2019Master
What firmware version are you running? Number not something like latest.
Can we net this out to if you plug into the switch from the router you lose wireless or am I missing something? Have seen a few reports of losing wireless when Ethernet device is used. Reason for firmware version.
- viall26Jan 19, 2019AspirantThe firmware version is v1.0.2.62. That is correct. Plug switch in to router and lose signal to wireless and ports in wired rooms.
viall26 wrote:
The firmware version is v1.0.2.62. That is correct. Plug switch in to router and lose signal to wireless and ports in wired rooms.Short of the famous reset router and start over with configuration I do not have a clue. As I said I have seen reports similar to this, but the .62 version of the firmware is supposed to fix some wireless issues.
You could try Voxel firmware. He sometimes fixes things Netgear has not. His firmware is based on Netgear with fixes and additions. Installs manually just like anyother Netgear firmware and for most folks just works. Would suggest a reset before doing an install should you go this way. Easy to come back should you want to by again doing a manual install this time with Netgear firmware.
Voxel firmware is here. https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
- pec967Jan 19, 2019Luminary
Do you have an Xbox connected via Ethernet to the R7800? If so, unplug it and see if your problems go away. There have been reports for more than two years of a problem like you describe.
I have a 16-port Netgear Ethernet switch (GS116Ev2) connected to my R7800 without problems. The only issue I experienced was having to disable IGMP Snooping on the GS116Ev2 to keep the AppleTV from disconnecting from the iTunes PC. This is some kind Bonjour incompatibility between the R7800 and the GS116Ev2.
Since firmware v 1.0.2.62 is so new, if all else fails you might drop back to v 1.0.2.52, which is what I am running. After flashing the firmware, reset with the button on the back of the R7800 and then configure manually.
- viall26Jan 19, 2019AspirantThank you. The XBox 1 is connected via wireless but I have plans to plug into the cat6 port into the wall. Unfortunately I’m no expert and to configure it manually is not something I would be comfortable with. I literally bought the switch because of the simplicity if plug and play.
On a side note I just downloaded the latest firmware so I will reset and try again in a little bit.
Thank you- pec967Jan 19, 2019Luminary
