Benjamin473
Apr 08, 2022Aspirant
Adding external antenna to R7000 Router
Hi, all I would like to add an external antenna (https://www.amazon.com/dp/B09DKZ7RNH) to my Nighthawk R7000/AC1900 can you advise as to which port I should connect it to? There's three antenna ports and I'm aware that in some instances you use the port furthest to the left, leaving the other two disconnected. Any advice?
The R7000 uses 3 separate ports for it's antennas.
- Benjamin473Aspirant
I'm aware of that, but what I am seeking clarity on is which port can I use for the external antenna. I'm also aware that you have to remove two antennas once you connect the external, but the question is which port do I connect the external. I've seen else where it says furthest to the left while some says furthest to the right
You can try plugging in and see. All 3 ports gets same data flow, there isn't a difference per port.
