Mystara2002's avatar
Mystara2002
"Additional log on information may be required" - Cannot connect
My router has started stating that 'additional log on information may be required' for one of my windows laptops.  Whenever I click the link, it asks me to sign into the router as an admin.
Additionally, if I try to visit a website, the router seems to intercept the request and instead asks me to log in as admin.  If I enter the login details, it just takes me to the router configuration page.  In either event, nothing else happens.  I am unable to connect to the internet.
The same laptop behaves normally with other routers, and other laptops behave correctly with this router.
I've already tried a hard reset.
Any ideas?
    • Mystara2002's avatar
      Mystara2002
      Yes, you could be right.
      My r7800 (in AP mode) is connected to an r8000, which is in turn connected to a modem/router provided by my ISP.
      Unfortunately, the modem/router does not have a bridge mode and I very recently turned on port forwarding for a server.
      I'm guessing my only option is to put the r8000 into bridge mode and effectively use my ISP's modem as the master?
      • plemans's avatar
        I'm guessing my only option is to put the r8000 into bridge mode and effectively use my ISP's modem as the master?------I think you mean AP mode.
        If your isp doesn't allow modem only mode, its probably the easiest way. You can fight to make it work but simplicity is sometimes the best.
