Reviewer
Jan 15, 2019Aspirant
Admin credentials not being accepted after facoty reset
I performed a factory reset by holding in the reset button (twenty seconds) until the lights turned amber
I used admin /admin, but it was not accepted.
The router password reset window opens an...
- Jan 15, 2019
the default user/password after reset is: user: admin password: password
Reviewer
They did not work.
I have the router attached by wire to a new router I purchased. I am trying to configure this on a Wireless Access Point.
Reviewer
I figured out that I needed to disconnect from the parent router.
Thank you for the suggestion :manhappy:
