JLRowan's avatar
JLRowan
Initiate
Jun 01, 2020
Admin login site is not secure
I logged in to my router as admin so I could update the password, but the connection is not secure.
Is this common, or is there something I can do to make it secure?
Thank you.
  • Thank you!  I appreciate the responses and explanation!
  • plemans's avatar
    its normal because you're on your local network. you're not "online".
    • antinode's avatar
      antinode
      Guru
         It's common to get complaints from a modern web browser when you use
      the router's management web site, because the browser is worried about
      your sending some user credentials over an unencrypted/insecure link
      ("http://" instead of "https://").  The easy thing to do is ignore the
      warning, and proceed.  Presumably, you're talking to your own gizmo on
      your own LAN.  If someone can overlisten to that local traffic, then
      you're already in big trouble.
         It's not "normal because you're on your local network."  It's
      (probably) _harmless_ because you're on your local network.  It's
      "normal" because a typical Netgear consumer-grade router uses HTTP, not
      HTTPS, for access to its management web site.
      • JLRowan's avatar
        JLRowan
        Initiate
