twfeeney's avatar
twfeeney
admin password question model R6700-100NAS
Where would I find the Admin password?  I can't move forward on set-up with out it.
  • FURRYe38's avatar
    Installation Guide or User manual PDF file online.
    Usually default is 'password'
    • twfeeney's avatar
      twfeeney
      password doesn't work.  Do I need to reset somehow?
      • plemans's avatar
        make sure about lower case. Its all lower case
        login: admin
        password: password
        all lower case.
        If you changed it from the defaults, then you'd need to use the password recovery feature.
        If you didn't set that up (it still asks the questions) or don't know the answers, then you'd need to factory reset to get back to the defaults.
