miketagg54's avatar
Jan 31, 2022
After installing new Nighthawk WiFi Router(R6900P) speed dropped to 10/100 mb out of switch from 1 G
After replacing and installing the new router I noticed that my speed dropped significantly on my eithernet coming from the new router.  I njormally have close to a gig of download and upload speed since I have fitber optic 1 GB1GB service.  My internet service coming into the router was tested and is at 1GB,  The Wifi signal emitted is also well above 100 MB.  I also tested the ether net ports and I found that the input from the router into a switch is good, but coming out of the switch that goes into a switch it drops in speed way down.  The indicator at the output from the router also is lit amber and if I move it to another port off the router the indicator of the port the output cable is moved to follows.  If I connect another ethernet to the router output and go directly into my PC the light turns white and the speed is back up to 1 GB.   So could this be the switch causing the issue?  The swithc is an 8 port unmanaged switch with currently 4 outputs and all 4 outputs from the switch speed have been degraded to less than 100 MB.   My main concern is that the router does show the 10/100 MB amber indicator so want to ensure it is not the new router and I may need to buy a new switch.  The current switch is 2 yrs old and have never had an issue with speed coming through it until now.
  • Would be yoru switch. If it's not connecting or supporting of 1000Mpbs, then you'll never see anything over 100Mpbs wired.
    What brand and model is this switch?
    Be sure your LAN cables are of good quality as well. CAT6 is recommended.
  • FURRYe38's avatar
    • miketagg54's avatar
      miketagg54
      Tutor
      It is a TP-Link TL-SG108 | 8 Port Gigabit Unmanaged Ethernet Network Switch.  It worked fine with my old router and all the outputs from the switch were well over the 100 MB that is coming out now.  I also have another small 4 port TP-Link switch and the outputs from that swit56ch are all acceptable.  I verified all my cables were tested and all do not seem to have an issue.  So agree it must be the switch has gone bad since it is unmanaged without any settings to adjust or test.   Thanks for your input.
      • FURRYe38's avatar
        I recommend NG GS-105/108v4 and GS308v3.
        Good Luck.
