SPUBOL
Jun 28, 2017Tutor
ALL Netgear USB Drive Mapping Issues ReadyShareConnect.exe ReadyShare Windows10 Map Network Drive
This reply will solve TWO Issues pertaining to Mapping a Windows Network Drive to your USB Connected Drive on your Netgear Router. This posting applies to ALL Netgear Routers utilizing Shared USB Win...
- Nov 15, 2017
This posting is from the author of the original post above. As of mid-OCT/2017 the Netgear Website lists updates for most of the current router models dealing with the SMBv1.x Issue described above. The beta solutions originally sent to me for testing by Netgear confirmed to me that the R8500 and the R9000 series routers have been "fixed". Please take the 3 minutes it will cost you to update your router firmware now. And please verify that you have indeed DISABLED SMBv1.x (NO Checkmark) in your Windows OS as per the instructions in the original thread of this posting. I have not encountered any issues with SAMSUNG or LG Smart TV's using files served from the Netgear Routers using Cable medium or WiFi, even with 5GB Plus 4K files.
SOLUTION: UPDATE ROUTER FIRMWARE NOV/2017
JamesGL
Jul 13, 2017NETGEAR Employee Retired
Hi SPUBOL,
This issue has been brought up already to NETGEAR.
Since the SMBv1 has security issue with wannacry, we recommend as well to report this in bug crowd.
http://www.netgear.com/about/security/
- MrRonGNov 14, 2017Aspirant
Is there a target date for the Samba upgrade for this router? The 2GB limit is quite inconvenient.
Am I better off abandoning NetGear FW and going open source?
JamesGL wrote:Hi SPUBOL,
- Retired_MemberNov 14, 2017
MrRonG wrote:Is there a target date for the Samba upgrade for this router? The 2GB limit is quite inconvenient.
They have fixed it on the R9000 with firmware beta V1.0.2.116_samba_fix, I have disabled SMB1, you can enable/disable SMB 1 to 3 and all files are at the correct size, lets hope they release this fix for all routers affected, as we all know, Netgear are not so quick with their support.
Regards
