Nav209
Jul 17, 2018Aspirant
"Allow guests to see each other and access my local network" is checked ON and greyed out in AP mode
Hi Community,
I can't seem to turn off the "Allow guests to see each other and access my local network" options on the Guest Network Setting on my R8000 or my R7000P routers. This is when the ...
- Jul 18, 2018
No, it's the absence of the isolation feature permitting full access and visibility between the wireless networks and the switched LAN ports. The whatever preset in place (coming probably from the router mode configuration) has no relevance.
schumaku
Jul 18, 2018Guru - Experienced User
The client isolation feature is not implemented and not available in pure AP mode - therefore the control is not available.
- Nav209Jul 18, 2018AspirantThank you.
However, is there then a different explanation why a smartphone on the 55CA network can use Chromecast speakers through Spotify set up on the NETGEAR network?
Thanks again,
Nav.- schumakuJul 18, 2018Guru - Experienced User
- Nav209Jul 18, 2018AspirantGot it now - ABSENCE of isolation!
Thanks.
