ShaggyRogers's avatar
ShaggyRogers
Android 5.1 Genie App Login Failure
Kindle Fire Genie App Login works smoothly. Android 4.4 Genie App Login works smoothly. Multiple phones running Android 5.1 repeatedly fail Genie App Login. States Login system busy, try again later.
