ShaggyRogers
Jan 22, 2016Aspirant
Android 5.1 Genie App Login Failure
Kindle Fire Genie App Login works smoothly. Android 4.4 Genie App Login works smoothly. Multiple phones running Android 5.1 repeatedly fail Genie App Login. States Login system busy, try again later.
- Jan 26, 2016
Hi @ShaggyRogers,
I was able to do some tests using the same version of Android and router firmware version and did not encounter any issues. Please try performing a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
ShaggyRogers
Jan 25, 2016Aspirant
Router Model: R7000
Firmware Version: V1.0.5.48
Android 5.1 devices fail login stating router busy try again later. All previous Android devices login just fine, including kindle fire HDX. Not isolated incident as per numerous other customer statements.
I can get by for now using my older devices. Would eventually like support for my barn new Android 5.1 phones.
DexterJB
Jan 25, 2016NETGEAR Moderator
Hi @ShaggyRogers,
1. Have you tried uninstalling and re-installing the app?
2. Did you modify the router password?
Dexter
Community Team
- ShaggyRogersJan 26, 2016Aspirant
Not a password problem as multiple other devices that are not Android 5.1 login just fine. Resetting. Uninstall are ineffective. I've been unsuccessful south 2 different router updates to change this issue. Android 4.4.4.1 phone logs in just fine. Kindle Fire HDX 4.5.5.1 works just fine. Windows 10.1 works just fine. Have never been able to login from Android 5.1 devices. Genie App version 2.4.26
- DexterJBJan 26, 2016NETGEAR Moderator
Hi @ShaggyRogers,
Dexter
Community Team
- ShaggyRogersJan 27, 2016Aspirant
DexterJB wrote:Hi @ShaggyRogers,
Dexter
Community Team
