ShaggyRogers
Jan 22, 2016Aspirant
Android 5.1 Genie App Login Failure
Kindle Fire Genie App Login works smoothly. Android 4.4 Genie App Login works smoothly. Multiple phones running Android 5.1 repeatedly fail Genie App Login. States Login system busy, try again later.
- Jan 26, 2016
Hi @ShaggyRogers,
I was able to do some tests using the same version of Android and router firmware version and did not encounter any issues. Please try performing a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
ShaggyRogers
Jan 26, 2016Aspirant
Not a password problem as multiple other devices that are not Android 5.1 login just fine. Resetting. Uninstall are ineffective. I've been unsuccessful south 2 different router updates to change this issue. Android 4.4.4.1 phone logs in just fine. Kindle Fire HDX 4.5.5.1 works just fine. Windows 10.1 works just fine. Have never been able to login from Android 5.1 devices. Genie App version 2.4.26
DexterJB
Jan 26, 2016NETGEAR Moderator
Hi @ShaggyRogers,
Dexter
Community Team
- ShaggyRogersJan 27, 2016Aspirant
DexterJB wrote:Hi @ShaggyRogers,
Dexter
Community Team
