swami7774's avatar
Jun 25, 2017
Another security upgrade issue: ambiguous instructions.
The instrutions say "under current versions, select the download that starts with "firmware version." On the page I;m getting, there are TWO such downloads: one says "Firmware Version 1.0.8.34 (North America only)"  while the other says "Firmware Version 1.0.7.12."
Which one should I download?
  • Hi swami7774,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi swami7774,
    If you are from NA, use the 1.0.8.34. For other regions, use the 1.0.7.12.
    • JamesGL's avatar
      JamesGL
      Hi swami7774,
      • swami7774's avatar
        swami7774
        Tutor
        My question re ambiguous installation instructions was resolved. Thanks for the help!
