dhsoule
Mar 28, 2017Tutor
Anyone with experience with R7300 connecting to Arris NVG448BQ via IP Passthrough Mode?
Does anyone have experience with installing either a R7000 AC 1900 router or the R7300 AC 1900 router with DST in connecting to an Arris NVG448BQ ADSL2+ from Frontier Communications? There is no tru...
- Mar 29, 2017
Mission accomplished! :smileylol: With some minor speedbumps I was able to get the gateway into IP passthrough mode. From there Netgear Genie made it very easy. Impressive. So far love the router. The DST adapter is being stubborn, but I live in a 40 year old home with old school electical. Need to work through that but otherwise up and running.
Thanks to all for your assistance.
William10a
Mar 28, 2017Master
Modem manual link https://www.dslreports.com/forum/r31139536-New-Gateways-FiOS-Vantage-Arris-NVG448BQ-NVG468MQ-NVG448B-NVG443B
It would easier to disable the modem/router 2.4 and 5 ghz radios and let the netgear be a access point and use it for the wifi connections instead of the arris modem/router a simple lan cable from one of the modem's lan port and connect it to the internet port of the netgear and you should be done. The modem you have is design for your isp the manual I found is from the FCC web site since have file specs on the networking equipement with them before they can use it the fcc id number is GZ5NVG4XXQ. Use 5NVG4xxQ for the fcc id number
I hope this helps.
dhsoule
Mar 28, 2017Tutor
Thank for the info, certainly something to consider. I cannot access the link for the manual as I don't have your credentials. Any way that you can post it for me to an ftp site or something along those lines?
- William10aMar 28, 2017Master
This link may work better for it is a link to arris http://www.arris.com/products/nvg44x-xdsl-voice-gateway/
Here is the data sheet fr the modem link http://www.arris.com/globalassets/resources/data-sheets/nvg44x_datasheet.pdf
Click on link fcc link 5NVG4XXQ the links must broken some how and select nvg448bq users manual
- dhsouleMar 28, 2017Tutor
Thanks got it. This is helpful. I also think that I brute forced the procedure for IP Passthrough for the NVG448BQ based on help from this forum, online searches and the documentation supplied by Arris for the NVG589. The GUI names and some parameters are different, but I feel much more confident than I did earlier today. Thanks again.
- dhsouleMar 29, 2017Tutor
