dhsoule
Mar 28, 2017Tutor
Anyone with experience with R7300 connecting to Arris NVG448BQ via IP Passthrough Mode?
Does anyone have experience with installing either a R7000 AC 1900 router or the R7300 AC 1900 router with DST in connecting to an Arris NVG448BQ ADSL2+ from Frontier Communications? There is no tru...
- Mar 29, 2017
Mission accomplished! :smileylol: With some minor speedbumps I was able to get the gateway into IP passthrough mode. From there Netgear Genie made it very easy. Impressive. So far love the router. The DST adapter is being stubborn, but I live in a 40 year old home with old school electical. Need to work through that but otherwise up and running.
Thanks to all for your assistance.
William10a
Mar 28, 2017Master
This link may work better for it is a link to arris http://www.arris.com/products/nvg44x-xdsl-voice-gateway/
Here is the data sheet fr the modem link http://www.arris.com/globalassets/resources/data-sheets/nvg44x_datasheet.pdf
Click on link fcc link 5NVG4XXQ the links must broken some how and select nvg448bq users manual
dhsoule
Mar 28, 2017Tutor
Thanks got it. This is helpful. I also think that I brute forced the procedure for IP Passthrough for the NVG448BQ based on help from this forum, online searches and the documentation supplied by Arris for the NVG589. The GUI names and some parameters are different, but I feel much more confident than I did earlier today. Thanks again.
- dhsouleMar 29, 2017Tutor
- William10aMar 29, 2017Master
I feel sorry for you rewiring a house can harder to live with that the internet you had .
- JC629Jul 25, 2017Initiate
I've got the same issue: just had Frontier installed & using the Arris model NVG468MQ. Wireless coverage is nowhere near what the Nighthawk provided. Could you give a bit of a detailed procedure for a router amateur?
Thanks!
