agudteach's avatar
agudteach
Anywhere Access on R7000 - only 2.4G devices showing.
AA software to remote access R7000 as I'm currently NOMAD.  Only 2.4Ghz devices show up and only 11 when I have 13 attached.  How do I enable to see the 5Ghz devices?  TIA
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi agudteach, are you still encountering this issue?
    • agudteach's avatar
      agudteach
      Yes, still having problem with only 2.4 showing up and not all devices attached show.
      Please advise.
      • michaelkenward's avatar
        michaelkenward
        Wow, you put up with that for more than four months before coming back?
        You might get more help if you said more about your network. We don't even know what firmware is on your R7000.
        You could also try a more detailed explanation of the problem. Brevity is great, but not at the expense of useful information and understanding.
        As this is about using an app to work with Anywhere Access, you could see if anyone can help in the apps zone.
        Nighthawk App - NETGEAR Communities
