evkrieken's avatar
evkrieken
Follower
May 04, 2017
APN Nighthawk R7100LG which APN with roaming
I am using this router only in my camper with a SIM-card, so using mobile broadband. The SIM-card is from Vodafone, the SIM pin is deacticated and roaming is on. So I am travelling through Europe pass...
  • JamesGL's avatar
    May 25, 2017
    Hi evkrieken,
    You should use the APN of the provider within the area since the Vodafone network is no longer available on the said country or area.
