Aaron65
Aug 01, 2015Aspirant
Are the the ethernet port lights supposed to be red when connected?
I have my pc connected through ethernet cable is the port light supposed to be red? The rest of the lights are white.
- The color of the light indicates the connection speed. White represents Gigabit and amber represents either 10 Mbps or 100 Mbps. - If your PC has a Gigabit Ethernet port, then you should verify that it's set to Gigabit mode. Else, check your Ethernet cable or try a different router port. - I've had a Ethernet cable that would only connect at 100 Mbps.
1 Reply
