cprice
Apr 04, 2018Aspirant
Arris surboard SBG6700-AC and Netgear NightHawk r6700v2
I'm having issues getting my modem(sbg6700-ac) to send a signal over to my NightHawk r6700 v2 router. I've restarted the modem several times and no luck. I've restarted the router while restarting t...
- Apr 09, 2018
I wanted solution 1 and I finally found the informatin that helped me. I'll provide the links in order inwhich they need to be performed.
Arris SBG6700-AC(modem/router combo)
This article explains how to configure the modem/router to modem only. Before I started I disconnected the coax cable and then reset the modem using the small white reset button on the back of the unit.(Press and hold until the lights turn off.) Note: Once the new router is installed I had to log back into this modem to disable the wireless functions.
After I followed the instructions in the article I reconnected the coax cable and connected the new wireless router to the modem while it was rebooting.
Netgear NightHawk r6700v2 or AC1750 smart wifi router.
Next, I connected an ethernet cable from one of the ports on the back to my computer to do the next step.
After this step was completed I was setup and ready to go..I currently have one issue. I can not log back into the Nighthawk router to make any changes if need be. I followed the steps in the article and have tried different url's as described in the article, but havan't been able to get access to the settings again. But I will get it figured out....I hope this helps...
cprice
Apr 09, 2018Aspirant
antinode
Apr 09, 2018Guru
> I wanted solution 1 [...]
Ok.
> https://kb.netgear.com/24104/ [...]
That's Option 1 AND Option 2, not Option 1 (exclusive-)OR Option 2.
You seem to be working too hard.
> [...] I can not log back into the Nighthawk router to make any changes
> if need be.
That's because an R6700v2, when configured as a WAP, does not use its
usual LAN IP address(es).
If you really did configure your SBG6700AC modem+router as a
modem-only ("bridge" mode), then you should probably reset your R6700v2
(which should return it to full-function-router mode), and start again.
> [...] But I will get it figured out....
Not that way.
> Solved! Go to Solution.
I don't think so.
