vince48's avatar
vince48
ATT U-verse
Greetings,
I;m very interested in getting a Nighthawk X10 to run my Plex. However, i have ATT U-verse as my ISP, how would i connect the Nighthawk X10 to my network?
  • Two options.
    1. Install as a router.  You should configure the AT&T U-Verse gateway to use IP Passthrough or DMZPlus.
    2. Install as an Access Point.
  • Two options.
    • vince48's avatar
      vince48
      Thank you much for the reply. Hopefully YouTube has a video to do the setup. Thanks again.
      vince48
