himelkari
May 01, 2022Follower
Attempting to set up a Netgear router with Nighthawk app, won't connect to internet
I've moved into a new apartment and am having to set up my own router for the first time. I bought a Netgear AC750 wifi router because it was cheap, which may have been my first mistake. The router...
May 02, 2022Guru - Experienced User
What router model did you buy? AC750 is a speed. It think the only AC750 router netgear makes is the R6020.
Its a super base model device.
What modem/gateway are you connecting it to?
If its new, you should have your 90 days of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
