poulet750's avatar
poulet750
ax 1800 mk 62
Bonjour,
j'ai acheter un router
MR60 — Routeur Wifi 6 Mesh
et quand je me connect dessus je n'ai pas d'internet. J'ai connecter et même reset le router en cliquant dessus 15sec. puis débranché et rebranchant et ensuite la lumière à changer de couleur quelque fois pour finir bleu et pourtant rien ne fonctionne.
Que dois je faire. Merci d'avance!
  • plemans's avatar
    What modem/gateway are you connecting it to?
  • michaelkenward's avatar
    michaelkenward
    As plemans says, we need more information.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Mesh System - NETGEAR Communities
    Then there is here:
    Français - NETGEAR Communities
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
