redbird97
Jan 19, 2022Aspirant
AX8 Nighthawk drops signal strength for no reason
So my AX8 will just drop the strength to all of my devices for no reason. I noticed it more since i began streaming games from my PC to my iPad. I checked the the signal strength in the app to my d...
Jan 20, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- redbird97Jan 20, 2022Aspirant
Firmware: 1.0.5.132_1.0.69
It's a Charter modem. That shouldn't have anything to do with the issue though as I'm not having an issue with the internet speed.
I live in the suburbs, there is no other wifi traffic.
- michaelkenwardJan 21, 2022Guru - Experienced User
That tells us nothing useful. Charter has supplied many different devices over the years. These days there is a good chance that they supply something that has everything to do with your Internet speed.
Suburbs = neighbours = wifi interference.
- redbird97Jan 21, 2022AspirantMaybe my message wasn’t clear enough. I have no issue with my internet speed. I have issue with signal strength dropping while streaming from my PC to my ipad. The modem and internet speed do not come into play whatsoever.
As far as wifi traffic. From any device in my house, if you look at available wifi, there is only my network. I do not receive any signal from a neighbors wifi.
