jgohn's avatar
jgohn
Follower
May 04, 2016
back to my mac
Nighthawk X6 R8000 Firmware Version V1.0.3.4_1.1.2, OS X EL Capitan 10.11.4, "Back to my Mac" does not work?
  • Hello JamesGL,
    I installed the latest firmware yesterday and it seems to work without the DMZ. Thank you for the heads-up. This makes me love my router even more! ;)
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi jgohn,
    Can you provide explanation for your issue? Provide screenshots as well.
    • GekkeHond's avatar
      GekkeHond
      I have the same problem. So I can help with the screenshots.
      This should work through icloud so I don't have te set up/remember ip adresses etc. My previous router did work (a D-Link N router). So it is not something that only works with an Apple router.
      Here is the Apple page about "Back to My Mac": Set up and use Back to My Mac
      And here are the screenshots:
      Preference
      Details:
      (it isn't slow, it just doesn't work).
      The end result is I cannot reach my mac outside of my own network.  It seems the UPnP does not work the way my iMac expects it to work (yes, I have UPnP turned on).
      • JamesGL's avatar
        JamesGL
        Hi GekkeHond,
        Can you set the IP address on the MAC computer to DMZ and check it will work?
  • It indeed does work when I put my iMac at home in the DMZ on my router.
    Any follow up's how I can get it to work with UPnP instead of the DMZ?
    • JamesGL's avatar
      JamesGL
      Hi GekkeHond,
      Try opening a port for your MAC. Check which port you need to open for "Back to my MAC".
        GekkeHond
        "Back to My Mac" doesn't use a static port.
        What I understood is that it uses my iCloud account on both devices to communicatie what port will be used on the moment I initiate the remote session, which can be anywhere between port 49152 to 65535. If I try to forward that range in the router I get an error it is already in use (which is true, there are UPnP portmaps active in that range).
        I guess that is why it needs UPnP to make sure the right port is forwarded at the moment it is needed.
        ps. Firmware Version  V1.0.5.70_1.1.91
        link about ports used my OS X: https://support.apple.com/en-us/HT202944
