philippis's avatar
philippis
BAD REQUEST when trying to safely remove USB device from R7500v2 using the latest firmware
I did not have this issue with the initial release firmware for my 2 R7500V2 routers.  After upgrade to the latest 1.0.2.4, I cannot safely remove my hard drives from the router, either single drive, or both, when clicking on the SAFELY REMOVE USB DEVICE button.  I get a BAD REQUEST page and the netgear page goes into a loading loop.  This seems like a bad bug.
  • No, it's definately the firmware.
    I reset the device as suggested.  I then tested the drives and got the same BAD REQUEST where it could not remove the USB drive.  I then updated the firmware to my previous 1.0.0.28 and the USB drive worked again.
    I have 2 of these routers, one as a bridge and one as a main router.  The main router has 2 6TB WD drives, and my bridge has a 1TB WD and 1 4TB WD.  After downgrading on BOTH routers the USB drive removal worked.
    This router is the R7500v2 I got in December when it was released.  I'm really surprised to see R7800 was released a month later.
    I guess for now, I won't be upgrading firmwares.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello philippis
    Welcome to the community!
    After upgrading to the latest firmware, did you factory reset the router?
    If not, I suggest that you push the reset button at the back of it with a paperclip for 10 seconds.
    Once done, reconfigure the router as if it's brand new out of the box.
    I am unable to replicate the problem you're having.
    • philippis's avatar
      philippis
