stu3791
Jan 06, 2022Aspirant
BASIC SET UP
I will keep this simple so where to you plug in the above router in your/my house. My house uk BT line comes in to socket then what? Because when i plug mine in i can get no internet? Yes phone li...
michaelkenward
Jan 07, 2022Guru - Experienced User
stu3791 wrote:
Is this not copatable with the UK network?.
Sure is, but you need the right equipment and settings.
Is this the same issue as the one you posted here?
nighthawk why - NETGEAR Communities
The details there are a bit different. So there doesn't seem to be much point in dealing with this conversation.
