sktn77a
Jan 08, 2026Virtuoso
Best WiFi 5 Router?
I have three (3) Netgear R7000 wifi 5 routers. All 3 are having issues with the 5GHz band intermittently dropping (design issue with the R7000)? I'm looking to replace all 3 with a wifi router with...
Jan 10, 2026Guru - Experienced User
If it were me, I'd pick up a used Orbi. You can get last gen's AX mesh systems for pretty reasonable prices. Even if you don't need the extra capability, it provides some updates, improved performance, and enhanced security. The RBK763 can usually be picked up refurbished for under $200
