wgd1350's avatar
wgd1350
Block an external IP address in Netgear R9000-100NAS Nighthawk X-10
I had an intruder logged in from a local IP that is a Comcast Public WiFi.  It is over a mile and a half away.  I want to block their IP.  I am not clear on how to do that.  I did not get a MAC address, only an IP.  Thanks,
WGD
  • Can you be more specific? What are they logged into? Your router? Your router's Wi-Fi? A machine on your home network?
    Depending on your answer, the appropriate action will generally be to either disable remote management, UPnP or port forwarding.
    • wgd1350's avatar
      wgd1350
      My bad.  Can we delete this thread.  I just realized it was the router linking to the Internet.
      Sorry,
      WGD
