Steve_18
Feb 20, 2021Follower
Bottleneck with JFS516 10/100
Hello,
I just got this switch to my hands, and I have a problem. I have a 30 Mb/s connection, but when running through the switch it only runs at less than 2 Mb/s. I only have connected two cables - the router and the computer. Is there a solution for this?
1 Reply
> [...] I have a 30 Mb/s connection, [...]
"connection" between what and what?
> [...] when running through the switch [...]
"when running" _what_ "through the switch"?
What, exactly, did you connect to what, exactly? What, exactly, are
you doing?> [...] it only runs at less than 2 Mb/s. [...]
"it"? _What_ "runs at less than 2 Mb/s"? Measured how?
> [...] I only have connected two cables - the router and the computer.
Is the speed higher if you connect them directly, instead of using
the (old, slow, but possibly adequate) network switch?Have you tested/swapped the cables?
> Model: JFS516|16 PORT 10/100 Mbps Fast Ethernet SwitchJFS516 or JFS516v2? Look for "Model" on the product label.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get some. Read. What do the LED
indicators on the switch indicate?
