KuTcH
Oct 23, 2017Aspirant
Bought nighthawk x10 and t9e when gaming i still get ping spikes when gaming
I tried everything from metered connections to cmd setting to even wall outlets for wired. I honestly don't know what to do here. When i play video games ill be fine and then my ping will shoot up to...
- Nov 29, 2017
Hi KuTcH,
Just to isolate if it is just wireless connection, can you check the wired connection if the same problem. If ever the same issue happens on wired, connect it directly to the modem to check if the issue is with the router or if it is from ISP.
ElaineM
Oct 30, 2017NETGEAR Employee Retired
Welcome to the community, KuTcH
What's the firmware installed on your router?
Did you try resetting the unit?
Which wireless signal you're connecting to?
Did you try changing channel?
How far are you from the wireless router?
KuTcH
Nov 19, 2017Aspirant
firmware V1.0.2.40
yes multiple times
tried both 2.4 and 5ghz
tried on 2.4 signals 1,6,11 all same problems tried random channels as well
roughly 40/50 ft
and i cant use powerline adapters because i live in a apartment complex, everythings been so frustrating
- JamesGLNov 29, 2017NETGEAR Employee Retired
Hi KuTcH,
- JamesGLDec 03, 2017NETGEAR Employee Retired
Hi KuTcH,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
