KuTcH's avatar
KuTcH
Bought nighthawk x10 and t9e when gaming i still get ping spikes when gaming
I tried everything from metered connections to cmd setting to even wall outlets for wired. I honestly don't know what to do here. When i play video games ill be fine and then my ping will shoot up to...
  • JamesGL's avatar
    JamesGL
    Nov 29, 2017
    Hi KuTcH,
    Just to isolate if it is just wireless connection, can you check the wired connection if the same problem. If ever the same issue happens on wired, connect it directly to the modem to check if the issue is with the router or if it is from ISP.
