Appleuser2000
Oct 02, 2015Guide
brand new R7000 issues
So after reading a lot of positive reviews and tests I bit the bullet and bought R7000 for $280, an upgrade from Linksys WRT310 N. I updated to the latest firmware to 1.0.4. Here is what happened. ...
- Oct 02, 2015
Here's a few tips that will hopefully keep you liking your R7000..
- (From experience - I have two of them) When you upgrade this router always do a factory reset after a firmware upgrade. There can be artifacts between the old fw or config that will cause grief on the router. Either way, it's best to start off with a clean slate.Never load an old version config on a new version of firmware.
-Ensure WMM is enabled on the router, always.
- QoS I would stay away from form as it impedes the Broadcom Cut Through Forwarding feature, especially if you have a 100+mb connection.
- Pick Wireless band channels, don't leave in auto mode. Try different channels. especially for 5ghz. (1,6,11 for 2.ghz). When you try different channels, reboot the router.
- 5ghz has better throughput, but shorter distance, as you have discovered. WIFI is based on environment, so not everything works the same for everyone.
- Not all routers are the same. Try getting the router up as high as possible and, in a well ventilated area, ideally, central to your environment.
- Antennae orientation should be like a "W" \ | /
Hope this helps
HVOSPkxa
Oct 28, 2015Star
Like you my coverage is not as good when using the 5G band. This is basic radio wave theory; the higher the frequency/shorter wavelenght the less distance the signal will travel. I also had difficulty connecting my Android tablet to the 5G band when standing next to the router, and when I did connect I would lose the connection and Android would then reconnect to the 2.4G band. Using the Netgear Genie there are few 5G signals around me.
My Solution was to change the channel to 42 from 157 on the 5G band and now I have a stable 5G connection using my android tablet around the house. In my case the channel made a huge difference even though there were no other 5G signals on the 157 channel around me, and I cannot explain why this is the case.
Good Luck!
Retired_Member
Nov 13, 2015The difference is the 3 digit 5g channels are able to broadcast at a higher RF output level which in your case I would had expected the opposite. The channels and power limits are different in each region/country. I would verify you selected the correct location and check for driver updates
