Appleuser2000
Oct 02, 2015Guide
brand new R7000 issues
So after reading a lot of positive reviews and tests I bit the bullet and bought R7000 for $280, an upgrade from Linksys WRT310 N. I updated to the latest firmware to 1.0.4. Here is what happened. ...
- Oct 02, 2015
Here's a few tips that will hopefully keep you liking your R7000..
- (From experience - I have two of them) When you upgrade this router always do a factory reset after a firmware upgrade. There can be artifacts between the old fw or config that will cause grief on the router. Either way, it's best to start off with a clean slate.Never load an old version config on a new version of firmware.
-Ensure WMM is enabled on the router, always.
- QoS I would stay away from form as it impedes the Broadcom Cut Through Forwarding feature, especially if you have a 100+mb connection.
- Pick Wireless band channels, don't leave in auto mode. Try different channels. especially for 5ghz. (1,6,11 for 2.ghz). When you try different channels, reboot the router.
- 5ghz has better throughput, but shorter distance, as you have discovered. WIFI is based on environment, so not everything works the same for everyone.
- Not all routers are the same. Try getting the router up as high as possible and, in a well ventilated area, ideally, central to your environment.
- Antennae orientation should be like a "W" \ | /
Hope this helps
Appleuser2000
Oct 02, 2015Guide
thanks friend...
I did as you told me, sadly there seems no extra coverage its exactlyl like or less than my '09 linksys. All those antennas and nothing more...
netwrks
Oct 02, 2015Master
Could be environmental. Can I ask if you have current drivers on your wireless client(s)?
- Appleuser2000Oct 02, 2015Guide
I am not sure what you mean by drivers. My router is brand new and I only installed the latest firmware. I didn't install anything on my computer or smartphones.
- netwrksOct 02, 2015Master
You should ensure that your desktop / laptop drivers (to make wireless work) are up to date. That is one part of the wireless puzzle.
