AbsolutZeroGI
Sep 23, 2019Aspirant
Brand new R8000 having speed issues
Hello, long time Netgear user, first time caller in the forums. I recently purchased an R8000 AC3200 to replace my aging (and dying) Nighthawk AC1900.
For a good 4-5 days I had no problems at all. However, today, the router basically dropped all download speeds. Upload speeds were unaffected and the download speeds returned after a reboot.
I know over time these routers get more and more finicky, but I'm a little concerned that the download speeds literally died in a week. Sure a reboot brougth them back, but is this a normal problem people have or did I just get unlucky once? Thank you!
AbsolutZeroGI wrote:Firmware: V1.0.4.46_10.1.63
When I click "check for update", it says there are no updates.
BAD BAD F/W that does cause problems.
You probably had V1.0.4.28 on the router when you bought it, but it also had AUTO-UPDATE enabled... and when that happened, you had the problem.
I suggest to log into Support at top, enter R8000 and select DOWNLOADS, then open PRIOR VERSIONS (+) and get selected V1.0.4.28. Click on the README for details on how to install the f/w. When told you are installing an older version do OK. Once the router reboots, TURN OF AUTO-UPDATE. Maybe the next f/w release might work, so keep checking here or on the Support tab to see if/when it is released.
- microchip8Master
Which firmware are you using? a number, not "the latest"
- AbsolutZeroGIAspirant
What's the modem, if any, in front of this thing?
