stevedarwin
Dec 19, 2018Aspirant
Bridge mode causes wireless to stop working r7000p to d6300
Want to use D6300 in bridged mode connected to R7000P and retain wireless connections through R7000P.
When the D6300 is powered up (has been placed in bridge mode) it stops the R7000P from connecti...
- Dec 19, 2018Thanks @Shumaku. Was thinking of the R series as I replied without coffee. Thank you for pointing this out. Changes everything. There is no way I would recommend trying to connect wirelessly in bridge mode. Would be a futile effort, as well as unreliable.
shadowsports
Dec 19, 2018Hero
Greetings,
It should be possible to use the D6300 as a modem in bridge mode in front of your R7000P. You will want to disable wireless on the D6300 and have it acting only as a "pass-through" device.
The R700P should be operating in router mode. It will perform NAT, DHCP and provide wireless connectivity.
