stevedarwin
Dec 19, 2018Aspirant
Bridge mode causes wireless to stop working r7000p to d6300
Want to use D6300 in bridged mode connected to R7000P and retain wireless connections through R7000P.
When the D6300 is powered up (has been placed in bridge mode) it stops the R7000P from connecti...
- Dec 19, 2018Thanks @Shumaku. Was thinking of the R series as I replied without coffee. Thank you for pointing this out. Changes everything. There is no way I would recommend trying to connect wirelessly in bridge mode. Would be a futile effort, as well as unreliable.
shadowsports
Dec 20, 2018Hero
Greetings. Not sure how much of a "solution" I provided here. Depending on wireless as the sole means for a bridge connection isn't robust or sustainable as you have discovered. Bridging over ethernet is preferred and what I would recommend. DSL is becoming less common but does suit some people's application or needs.
stevedarwin
Dec 24, 2018Aspirant
Just an update for those who have helped so far.
Have connected D6300 in bridge mode via ethernet cable and all appears to working fine.
Not what I wanted, but it works.
Will maybe still have a go at the wireless setup, but don't hold your breath waiting for an update
Thanks again
