blshaw45
Aug 24, 2020Aspirant
Bridge mode disables radios
I am trying to help a neighbor with a significant WiFi problem. He is totally unfamilar with the technology while I have a little bit more experience but, apparently, not enough.
In his residnce he has a Netgear WiFi modem/router that serves most of that building well (I don't know the model, but can inquire if that info is needed). An adjacent garage has a "man cave" below. He wants to extend his network to the garage so he bought a Nighthawk X65 extender. However, the man cave is surrounded by a rock veneer wall without windows and the garage's concrete slab above, so the signal from the primary router does not penetrate into the man cave at all; the extender is therefore useless there (it is now used in anoither section of the main home).
He also has a Nertgear AC1900 C7000 modem/router that I thought/hoped we could set up in bridge mode and connect it back to the primary router via Ethernet (we can get a CAT-5/6 cable between the two buildings). I brought the C7000 to my home to experiment with before we go to the trouble of installing a 100-foot cable at the site. But as soon as I set Router Mode to 'off' and the device reboots, the radios are turned oiff and can't be turned back on.
So to my question: is there any way to use the C7000 as a extender using a wired connection back to the primary router and, if so, how would I go about that? If that can't be made to work, is there any other wire-based option in the Netgear product mix that can addressw this application?
Any help will be greatly appreciated.
What, exactly, does "Bridge mode" mean to you? This term is greatly
over-/mis-used, leading to many misunderstandings.> [...] as soon as I set Router Mode to 'off' and the device reboots,
> the radios are turned oiff and can't be turned back on.Right. If you're looking at "Cable Your Modem Router to a Router and
Use Bridge Mode" in the C7000 User Manual, then setting ADVANCED >
Administration > Router Mode to "Off" means disabling the router
entirely, leaving only the modem (in "bridge mode", meaning about as
stupid as a piece of wire). No routing, no radios, only an Ethernet
port which you can connect to a real router (or a single
computer/device). Not what you want.> [...] connect it back to the primary router via Ethernet (we can get a
If you leave out the "bridge mode" description, then what you really
want is a wireless access point (WAP). The C7000 does not formally
offer a WAP mode, but almost any router can be configured as a WAP,
including a C7000. See, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option.
option.- blshaw45Aspirant
Many thanks!! Makes sense. I'll give 'er a try tomorrow.
