Chacej
Nov 17, 2017Follower
Brother MFC-L24740DW doesn't recognize WPA (AES)
Hi,
My Brother printer used to connect to my wifi over WPA (AES) and worked fine. I updated my router firmware to version 1.0.3.54_1.1.37 and the router now says no new firmware available. Since the update my Brother MFC-L24740DW cannot connect and goives error TS-04 which means the authentication/encryption of the wireless lan is not support. It then goes on to say use WPA TKIP or AES which I am. I have updated the firmware on the printer and still get the error.
I think the latest firmware update that fixed a WPA vulnerability has a bug that now the printer can't connect. Has anyone run into this and found a way to fix it?
Hi Chacej,
Try to reset the router and reconfigure it manually.If you use TKIP, will it work?
