Gizzard
Jul 24, 2015Star
BT Vision (UK IPTV / Internet) - Multicast + Unicast on same wired port??
Hi, I recently bought a Nighthawk R8000 to replace my BT Home Hub 4. All went well until I checked the BT Vision service I have. This box uses standard internet and multicast for TV services. ...
- Jul 11, 2016
Hello All,
Here's a trial firmware that you may try to get it working.
Gizzard
Aug 01, 2015Star
Hi Elaine... knowing my top of the range netgear can do what my old BT Home hub can do is very disappointing. Do you have an ETA for this feature?
Thanks Wayne.
Thanks Wayne.
- SnowmattAug 03, 2015Tutor
I agree with this. My router is an R7000, but having the same issue. These routers are high end and an such should have high end support. BT vision has been available for some time, so there should have been plenty of time the nighthawk routers to be updated to work as replacement for the stock routers.
- GizzardAug 03, 2015Star
Correcting typo: "Hi Elaine... knowing my top of the range netgear can't do what my old BT Home hub can do is very disappointing. Do you have an ETA for this feature?
Thanks Wayne."- ElaineMAug 03, 2015NETGEAR Employee Retired
Hi Wayne,
Unfortunately, we do not have an ETA for this. However, I highly recommend you post this as an Idea in this board to get more attention.
- wallagegdMay 13, 2016Tutor
It has now been several months since the future fw was promised. And the feature has been deployed to other routers...
When is this going to be rolled out to the R8000?
