TKwsNi
Jan 06, 2026Aspirant
Burnt smd, need help to identify Netgear R6900v2
By mistake in emergency I inverted the polarity of the DC adapter voltage and burnt an smd and the router doesnt turn on now, there is a low frequency sound but thats it, I need to identify this smd ...
TKwsNi
Jan 08, 2026Aspirant
Nothing visible in the fcc, the internal pictures are low quality
Jan 08, 2026Guru - Experienced User
Plenty of R6900v2 routers on ebay, some under $25 USD. So maybe just buy one, and either use it instead of the one you damaged, or take off the chip you need.
- TKwsNiJan 09, 2026Aspirant
I know, but i'm not in the US, buying one now is expensive for me, thats why i'm trying to repair this
