Raehm's avatar
Raehm
Follower
Jan 17, 2021
C6250 router login problem
I bought this as a "remanufactured" unit, where the original router login un and pw were not erased.  How do I access the router control panel  www.routerlogin.net (192.0168.0.1) to update the un and pw?
  • I would start fresh to ensure it was fully erased.
    Push and hold reset for 7-15 seconds while its powered on.
    that should get you back to the defaults
    default login: admin
    default password: password
    you can also try access it at 192.168.100.1 (default modem ip address)
1 Reply
  • plemans's avatar
