victoriazoe's avatar
victoriazoe
Follower
Jan 19, 2021
C6300
Whenever trying to use my router, my router keeps saying its connected but no internet. Please help!!!! I've tried changing the channels and that is not working.
  • plemans's avatar
    Do you have a screen snip of the cable connections page and the event logs?
    I'd also check your coax line going to the C6300 for kinks, damage, loose/old/bad connections, make sure the RG6 is quality cable.
  • michaelkenward's avatar
    michaelkenward
    The  C6300 is a modem router.
    Does it have an Internet connection? What do the LEDs show? Downstream? Upstream? Internet?
    What says " its connected but no internet"? Some wifi thing?
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
