jkgonzal's avatar
jkgonzal
Follower
Dec 08, 2021
Camera system
I have trying to work on security system. It has a camera 1/2 mile away. I need a access point that will go that far and a recover that will send the camera signal back. What do you recommend
James Gonzales
  • FURRYe38's avatar
    Half mile away. Ya, thats a bit of a range thats too far for home class routers and wifi APs.
    I recommend you find a camera that is wired or set with a on site security system. Contact the Mfr of these cameras for there help and information on what suggestions could be used for remote distance cameras.
  • Ubiquiti makes a nanostation that works for security cameras.  I utilize something for security cameras here over a wide range.  I don't know how easy they are to install and setup though as I had mine professionally installed...but they seem to work like a basic repeater of a signal from a camera to your security camera server or NVR.  Just google Ubiquiti nanostation or antenna
