_jakerowe_
Aug 09, 2017Aspirant
Can’t Connect to Router Configured as Wireless AP
Hello everyone. So my wireless router is set to wireless AP mode and my modem is on bridge mode, and now I cannot access the internet at all or the router settings to try and fix it. I’ve even tried p...
- Aug 09, 2017I hadn’t realized that my gateway was on bridge mode until it was too late, but I have since resolved the issue and everything is working fine now. Thank you for your input :)
To fix the issue I simply reset my router to the factory settings (although I didn’t want to) but I did not know if any other way to fix the problem because there was no way to actually connect to the router. From there I just set up the router the way I did before just without Wireless AP mode on.
TheEther
Aug 09, 2017Guru
Why did you set the router to AP mode and the modem to bridge mode? You should have exactly one device functioning as a router.
- _jakerowe_Aug 09, 2017AspirantI hadn’t realized that my gateway was on bridge mode until it was too late, but I have since resolved the issue and everything is working fine now. Thank you for your input :)
