TerryJ40's avatar
TerryJ40
Can’t get a wireless printer to work on my network
  • FURRYe38's avatar
    Something to contact the printers Mfr about and ask for help and information regarding there product.
  • plemans's avatar
    What router do you have?
    What firmware is on it?
    What printer are you installing?
    Where does it fail in the process? and what errors are you getting
    Its tough to help without details
    • TerryJ40's avatar
      TerryJ40
      It installs ok but when you go to print it can't hook up with it
      • plemans's avatar
        You didn't really give us anymore details. tough to help without those.
        If its a new printer, contact the manufacturer.
        If its a new router, contact support.
        To get a hold of support. Click on "MyNetgear" at the top.
        Register an account (or login) and then the device.
        From there you can start the support process. Keep in mind that its only free for the first 90 days.
